跳转到主内容
加入维修社区 - 创建账户
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Battery : replace now
My battery says ‘replace now’, but has only completed 670 cycles. Do I need to replace? Here is a readout from coconut battery. Any advice would be appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
As per your photo, your battery currently has zero charge in it and is only capable of holding 217mAh out of its original 6559mAh, a reduction of about 97%. So, yes, replace your battery.
这个答案有帮助吗?
得分 1
3条评论:
thanks steve. I thought MacBook pro batteries like mine were meant to last for 0ver 1000 cycles? must have got a dud. Must say, not that impressed with apple, the retina screen is faulty also
完成的
Bad parts happen; that's life. You might be able to persuade Apple to replace your battery at no cost since it's well below their quoted 1000-cycle life, but they can just as easily argue that poor battery maintenance was the culprit. Still, worth a shot.
Don't know about your screen issues.
完成的
You'll get fewer cycles when you always do deep discharge and charge cycles. 600 is about right if thats what you tend to do.
While its not always easy to do, try to leave your system plugged in as much as possible. every time you drop to less than 1/3 of the batteries charge you burn a cycle.
as an example, my 2012 15" MacBook Pro has only used 60 cycles and still going strong! As I mostly have it connected to the charger. Yet, my 2011 17" which I use in the field when I'm shooting is now 650 cycles. Unlike my 15 I often run the battery down and its now hitting Poor status so I'll need to replace the battery before I go back out in the Spring.
完成的
添加一条评论
添加你的答案
David 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 83
