跳转到主内容
加入维修社区 - 创建账户
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
Home button do not respond
Home button do not respond time by time.
And ear speaker so quiet. No any damages or
water spills. Thanks for help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
any ideas guys?
完成的
添加一条评论
1个答案
已选择的解决方案
The home button not responding is probably the result of dust or a poor connection in the logic board. Here's a teardown to open it up and check out the connections. You can also blow some compressed air inside to clear out any dust.
As for the ear speaker, it's possible that there is a bad connection between the speaker and the logic board. More likely, however, is that the speaker is dying and needs to be replaced. Both can be done with the same teardown guide.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vitali 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 11
过去 30 天: 11
总计 767
