跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Tin can audio from replacement screen iPhone 6s
I replaced the screen on my iPhone 6s using an iFixit part and now the audio during phone calls is horrible. The audio rattles, there are high pitched artifacts. It sounds like a blown speaker. The screen installation went perfectly. No problems. I just followed the instructions and it all went smoothly. But now the audio sounds awful. What’s going on?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
If the screen from iFixit was preassembled with the earpiece speaker preinstalled you can transfer the old one from the old screen to the replacement screen and that should do the trick.
这个答案有帮助吗?
得分 2
1条评论:
I removed the replacement ear piece speaker module and used the original module and that fixed the problem. Thank you! I shouldn't have had to do that though. The one with the replacement screen should not have been bad. :(
完成的
添加一条评论
In my experience, Tin Can Audio occurs when a front flex is partially damaged during removal. That little bugger is so friggin’ fragile, I feel like have to do have to superstitious things like play soothing music around the phone being repaired or I get Tin Can Audio, or an Ambient Light Sensor fails.
To resolve the issue, you can reseat the front flex and earpiece, that may help. If that doesn’t work, Ben’s suggestion is the next best solution.
这个答案有帮助吗?
得分 0
1条评论:
I ended up using the original ear piece module. The flex cable appeared to be correctly seated and undamaged. I used a powerful magnifier lamp to examine it. The ambient light sensor and camera were working so I think that I had the connector right. I agree that it is a fiddly little thing though.
完成的
添加一条评论
添加你的答案
Bryant Bunderson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 52
