跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Strange Battery Issue Capacity
I’ve changed an iPhone 6 battery twice now and it will show 100 percent capacity in settings battery and also coconut battery and 3utools. I also have a battery tester machine and shows the same thing. Anyways, after about two weeks, the battery is at 70 percent and the settings says service. I’ve tested with 3utools and my machine and also shows 70 percent… This happened twice now and I’ve never had this kind of issue before. Would a u2 ic chip cause this issue? Or is this battery related? The phone has been wiped dfu mode etc and nothing has changed
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Depending on where you source your batteries, it could very well be poor quality batteries. However, a defective charge circuit could also damage the batteries although I’m a bit skeptical that it could cause as much degradation as your seeing.
If this is happening on your own device, it will be hard to troubleshoot because Ideally you need to have either a known-good battery or known-good device to properly troubleshoot this issue. An independent repair shop may be able to help you.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Daniel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 94
