跳转到主内容
家用物品维修 DIY 指南,从家具到下水管道解决应有尽有。
3888 个问题 查看全部
OC White Magnifying Flourescent Lamp, not lighting?
Model is Vision Lite 2000 by OC White. Maker no longer has parts or repair info. Lamp bulb is good. Variable intensity capable. Has solid state PC board for ballast. Board has no identifying marks. IC on board not identifiable. 50 or so discreet components. Fuse is good. Need any info possible to troubleshoot/repair/replace!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi Bill
Possible to share some pictures here for us to have a look?
完成的
Photos added, thanks for responding!
完成的
添加一条评论
2个答案
已选择的解决方案
Hi,
Have you seen it working before?
Just looking at the pictures of the board it appears as though Q1 has been removed, also R31. It looks like the board has been worked on.
Looking at other electronic ballast circuits they all seem to have 2 driver transistors controlled by a "chip", whereas on yours I can only see the one.
这个答案有帮助吗?
得分 1
1条评论:
What good eyes you have! I was testing the two mosfets and had one out when my grandson took the pic. The llight worked briefly out of the box but died after 2-3 turn ons. I sent it to OCWhite for fix but they declined so I don't know what was done to it. Schematic anyone? Non-desecrated IC part number? Is the missing resistor in a working light? Does Luxo have a swap out ballast? Why is the sky blue? Yes, I have been investigating an LED solution but the purist in me wants to FIX the original. PS: the mosfets tested good.
完成的
添加一条评论
It does look like components are missing from the board. I personally would rip out the preexisting components and just do an LED mod on it, you won't have a dimming feature but they will definitely out perform a flo bulb.
这个答案有帮助吗?
得分 0
3条评论:
I am investigating an LED solution. Maybe using the strip lamps out of the free stick up switches from harborfreight. Xure would like to fix the original though! Have you seen any good conversions on utube?
完成的
I do led mod to screens all the time as I am a casino tech. Led strip to the luminosity you want with a 12v psu, you can cut the strips to the size you want.
完成的
May I have the details and source of the tape? Thx, Bill
完成的
添加一条评论
添加你的答案
Bill G 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 7
总计 266
