跳转到主内容
与AirPort Extreme基站一起发布,这款配备硬盘的Time Capsule NAS上提供802.11ac速度。
56 个问题 查看全部
I can no longer access the 3GB drive anymore how do I open it
I can no longer access the 3GB drive in the Time Capsule. The WiFi router is still working OK and the Time capsule is listed in the left column of finder windows but when I try to connect to the drive via WiFi or Ethernet I just get a message that there is a problem connecting. I want to try removing the drive to test it separately to try to save the data and maybe replace the drive but…
How do I open the time capsule?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
It’s pretty easy, you just open up the bottom, disconnect some cords, and pull it out (basically). iFixit has a guide with full details you can follow.
这个答案有帮助吗?
得分 1
添加一条评论
Do keep in mind the drives format is unique to the TC (it is not natively mac readable). If you really need to save the data you'll need to transfer to another A1470 capsule. Thats assuming the drive is still good.
Your other option is to use a data recovery app like Stelalr
Often times the power supplies go
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
frank 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 10
总计 128
