跳转到主内容
Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
157 个问题 查看全部
Can't get the vibrators out
So my remote had the entire left handle sheared off,
but it still works so im gonna try to fix the damage, but i cant seem to get the vibrators out as the guides appear to have different models (if that's even a thing idk) and so im kinda stick. Appeceriate help.if possible
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
First thing I usually check when I am experiencing difficulties with any repair is how the part looks to be secured. Check if it looks like there is adhesive or if there is small screws. Obviously both would prevent you from removing the vibrators. I will assume there are no screws because it should be obvious is there is. Again assuming it is adhesive the easiest way to soften/weaken the adhesive is using isopropyl alcohol. This should break down the glue enough to allow you to carefully pry the vibrators out. You can use a spudger if you have one, if not a small flat head screwdriver and make sure not to pry on any points that could break off (like in between the body and rotating weight) but rather somewhere like the main body (the larger, metal section) of the vibrator. Hope that helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
TaloNNn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 135
