跳转到主内容
Repair guides and support for full size headphones that encompass the entire ear, also known as circumaural headphones.
108 个问题 查看全部
How can I fix the power slide on my COWIN E7 BLUETOOTH HEADPHONES
My headphones dropped off of my head onto the tile floor in my school, the slide for off, regular mode, and noise cancelling, got pushed all the way in but my headphones were still on. When I got home, I got a pair of tweezers to pull the back out to where its supposed to be, I was successful in that but, they won’t turn off and they’re stuck on noise cancelling, is there anything I can do to fix the slide back to normal or is there somewhere I have to go to get it fixed?
As you can see from the picture or if you can’t see it, the switch is on off and they are still on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
My suggestion is get a size 6, 6-point screwdriver and open up that side of the headphones. Don’t push the switch back into place until you are absolutely sure it won’t snap off.
这个答案有帮助吗?
得分 0
1条评论:
There is no access to the switch from there as far as I can tell.
完成的
添加一条评论
添加你的答案
Joshuwolf Gaming 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 19
总计 716
