跳转到主内容
LG的旗舰智能手机,具有独特的滑出电池和可拆卸的I/O模块,支持多种硬件扩展选项。发布于2016年4月。
Is it possible to replace a contact spring on Motherboard?
Hi:
I received an LG G5 model VS987 phone. It was reported the power button did not function but on closer inspection I found 3 contact springs on the motherboard that are broken- these connect with the power button on the back panel. I have safely removed the 3 broken contact springs, and removed three good ones from another motherboard for replacements. But, how can I safely solder the new contacts to the good motherboard? Anyone done this already?
Thanks!
Tom
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thanks for your input…
Actually I`ve started researching SMD rework stations (uses hot air), that is how I will go. All this is still a bit new to me.
完成的
添加一条评论
1个答案
最有帮助的答案
Just use good tweezers and hot air at about 450c should do the
这个答案有帮助吗?
得分 1
1条评论:
Is there a video you can post on where the motherboard is broken? I have the same issue with my power button which I've already replaced yet it is still not working.
完成的
添加一条评论
添加你的答案
Tom 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 292
