跳转到主内容
Smart fitness watch via Bluetooth, released in March 2016. Model: FB502SBUL
53 个问题 查看全部
Fitbit Blaze only works in charger
My Fitbit Blaze works fine in the charger but shuts off immediately if the charger is unplugged or the watch is taken out of the charger. Can’t even reset using the reset procedure from Fitbit as there is no power at all. Shows 100% when in the charger. Is the battery a realistic possibility? It can’t imagine it is but the alternative sucks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
If it works on the charger but not when on the battery only, then most likely the battery has failed and needs to be replaced.
Here’s a link to the ifixit Fitbit Blaze 电池更换 guide, which shows how to replace the battery.
ifixit sell a battery for the watch. Here’s a link Fitbit Blaze Battery
There are also other suppliers that may suit you better. Just search online for LSSP321830 to get results.
Fitbit Blaze Battery图片
产品
$19.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Chris Chandler 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 64
总计 5,100
