跳转到主内容
加入维修社区 - 创建账户
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
home button sometimes works
So I have looked for articles on this but I can’t seem to find a similar case. So I just replaced my wife’s iPhone 7 plus screen and it was perfectly easy to do and the screen quality is great! This morning my wife said that every once in a while her home button wouldn’t respond but then it would. I grabbed her phone and confirmed, almost every hundred or so clicks, it stops but then immediately starts..any help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
There is a very fragile ribbon cable that attaches to the home button from the body of the phone. This cable may have been damaged during the screen replacement that you had performed, and the way to fix this is to open the phone and check and see if the home button cable is plugged in all the way. If it is, then the cable itself may be damaged and you may need a new home button. Note that replacement home buttons do not work with touch ID since it has to be the original home button for it to work. Hopefully this helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alexander Lehman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 85
