Screen uneven after repair?
Yesterday I replaced the battery of my iPhone 5, and while the phone functions normally, there's a slight hiccup-- the top left corner of the phone is raised a bit higher than the other corners. I pried open the phone again to confirm the new battery wasn’t tilted or lopsided, but that one corner still can’t seem to settle like the others. What do you think the cause could be? Thanks!
4条评论
Can you add pictures? Is it like a big gap or just a slight difference in height? It doesn't really make sense for a top corner to be raised on an iPhone display design, it could be a flaw in whatever screen you purchased.
由 Jonah Aragon 完成的
Pics added! It's most pronounced when viewed from the left side. Thanks
由 Sgottsch 完成的
Is this the original screen? What was the issue with the old battery, did you replace it because it was bulging?
由 Jonah Aragon 完成的
It's the original with a screen protector on top of it-- I replaced the battery because it started depleting too quickly. Not sure if the original bulged at all. Thanks
由 Sgottsch 完成的
