跳转到主内容
CPU Panik?! MacBook not booting. Stuck on loading screen. With error
Hey there,
i have a macbook Pro 2010 13” with an Error massege popping up on start up.
It chimes and everythink looks pretty good, but it wont boot up.
I am aware of the 2010 GPU kernel Panic issue but I tought its just the 15” Macbooks. And this seems to be something different?
Thanks for your help. Pease üt-
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You have a page fault condition, this is when you either have a RAM or HD problem.
I would take the time to clean the memory module contacts and reseat them. In addition I would reboot under the recovery partition so you can run Disk Utility to check the drive. I would look at replacing the HD SATA cable and the drive with a larger one.
这个答案有帮助吗?
得分 0
7条评论:
Thanks for the answer i cleaned the cntacts with alcohol . i am trying to start it from a usb stick. is the image corrupt? Still not working...
完成的
What is the bootable USB drive doing?
Are you sure it's the boot drive?
完成的
yes i am trying to run the install from it. and i choosen it via alt on boot
完成的
the error is not allways displayed most of the time it just freezes
完成的
Replace the RAM: 204-pin PC3-8500 (1066 MHz) DDR3 SO-DIMM's
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Niklas Jakob 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 228
