跳转到主内容
Repair information for standalone freezers.
Why does it stop after freezing for a while
if I turn on my refrigerator, the freezer will work for just 15-20mins then stop freezing. but it will continue cooling
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Maybe it's reached the set temperature. If you have a thermometer put it in the freezer to check the temperature. If it's not cold enough adjust the thermostat, and keep using thermometer until you get the temperature you're looking for.
这个答案有帮助吗?
得分 0
1条评论:
the thermostat is already at its highest point (7), but what i discovered was that the coil at the back was warm/hot for some mins and then stopped
完成的
添加一条评论
添加你的答案
olupona temidayo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 56
