跳转到主内容
Repair guides and support for SD, miniSD and microSD memory cards used in tablets, phones and cameras.
SD card cracked on the side
I stepped on my SD card (64 GB SanDisk Ultra) and it cracked on the side. I was wondering if I could recover it somehow. I spent three days with random recovery software programs. The SD card can be seen by the computer and the programs, but when you “recover” the files, all of them are empty with no photos nor any videos.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
Is the board damaged at all or is it just the casing? a lot of modern SD cards are empty space, so it may just not be able to seat correctly with the case damage.
完成的
I do not think it is just the case. Is it possible to recover any photographs if the board is damaged?
完成的
Probably not, unfortunately. I would take off the casing to be sure though. If it isn't damaged, you can put it in the casing for a card of the same model to be able to seat it correctly, and get the data off of it. I wouldn't expect the card to hold up well after swapping the cases but it will let you pull your photos off at least.
完成的
I agree with Ian
完成的
Thank you, Ian. I appreciate your assistance. I'll let you know if it works.
完成的
添加一条评论
1个答案
已选择的解决方案
An SD card is really just a small circuit board with a memory IC and a controller IC and the board is inside the plastic housing.
Now, if you stepped on it, then chances are something broke physically inside. It could be the circuit board (damaged traces or layers), it could be the IC’s soldered connections or the actual IC’s themselves. If your computer can “see” the card but not the data, I would suspect the issue is with the memory IC’s.
Someone who does micro-soldering may be able to recover the data by repairing the board or the soldered connections (or even transplanting the IC’s to an IDENTICAL board). Finally, the data may be recoverable directly from the memory IC’s via a process called Chip-Off data recovery if the controller is bad but the memory IC is still good.
At the end of the day, it’ll probably come down to how much you are willing to pay to get this data although there are circumstances which may make the data totally unrecoverable (damaged memory IC, encrypted data, no “solutions” for the controller etc.).
A good data recovery/micro-soldering shop should be able to do a proper diagnostic and many of them work on a No Data/No Fee basis.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Misha 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 17
总计 3,161
