跳转到主内容
加入维修社区 - 创建账户
The 6th-generation Surface Pro, released in October 2018. Available in platinum and black. Model number: 1796.
Can you upgrade the ram on the Surface pro 6?
i was asking to see if i can upgrade the ram on the Microsoft surface Pro 6?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
已选择的解决方案
The Surface Pro design includes RAM that’s soldered to the motherboard, and so without major “gut renovation” this cannot be accomplished.
这个答案有帮助吗?
得分 4
添加一条评论
You can’t add RAM. But that might not be your problem. You’ve probably maxed out your hard drive, like my wife, and so the computer is bogged way down and slow. On the back of the case, under the FLAP, there is a micro-SD card slot. You can put as big a card as you want in there. I just put a 256gb micro sd card, which doubled the storage for $50. This, coupled with deleting useless apps and files, should make it run faster. When you’re out of RAM, the computer uses mass storage for “Swap files”. This is why this works.
这个答案有帮助吗?
得分 2
2条评论:
Make sure it's fast though. I bought a SanDisk Extreme with 400GB on Amazon because my drive was always full (Its always on discount). Strangely, since I got it I now somehow got plenty of free storage on my C: drive and don't need it after all, but if I want to load Android on my Surface sometime again I should have no problems with partitioning my storage ^^
完成的
How can i do that ?
完成的
添加一条评论
The RAM is soldered to the motherboard. So, it would be extremely difficult to upgrade.
这个答案有帮助吗?
得分 1
1条评论:
how difficult exactly? are there any guides online
完成的
添加一条评论
添加你的答案
Marwan Mohamed 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 34
过去 30 天: 117
总计 32,587
