跳转到主内容
An SSD, or Solid State Drive, is a type of storage device that uses NAND-based flash memory to store data.
SSD failed to restore
APFS failed to invert. OSS Error 22
Update (02/14/2019)
Mac mini (Late 2014) running Mojave (10.14.3).
I was able to clone the drive with the Carbon Copy Clone app. I'll know today if it was successful after I install it.
Thanks Jonah
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
What is the exact Mac system you are using as well as the drives specs.
完成的
添加一条评论
2个答案
已选择的解决方案
Success! The SSD is up and running.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Disk Utility no longer works with APFS file systems for restoring/cloning devices. Using a Time Machine backup or Target Disk Mode on an old computer are the only ways to transfer data.
这个答案有帮助吗?
得分 1
3条评论:
Don't know why you're talking about Disk Utility here as we still have no idea what the system is. Until we get that you're just shooting in the dark.
FYI: The cloning options are no longer present in the latest version of Disk Utility
完成的
Are you restoring the drive with CCC or Disk Utility? I just want to double check where you’re actually seeing this error.
完成的
Error was with disk utility. CCC worked perfectly. Up and running!
完成的
添加一条评论
添加你的答案
Kenneth Hillman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 602
