跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 个问题 查看全部
No display and no backlight
Hi,
I’m have problem with my Early 2013 MacBook Pro it has no backlight.
Tried with knowing good display, no image at all on external display.
Backlight Fuse working fine, but there is small IC chip shows small burning
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Can you give us some background information on what happened to the system to start with.
To be clear you don't see anything on the external display
完成的
Suddenly display goes off and not respond
Tried reset SMC and PRAM
Checked Backlight fuse is ok with Buzzer
Tried with knowing good display issue still occurs ?!
Tried with External there is signal and working normally on external Display!
as you can see in pic , like burning on this crystal iC !!
完成的
添加一条评论
1个答案
Q3880 - SI8409DB - P-Channel 30 V (D-S) MOSFET
I think you need to dig deeper here as this likely was damaged by something else going bad on your logic board. I would get the schematics and board view drawings so you can properly diagnose the problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mohamed Ghaly 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 324
