跳转到主内容
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428 个问题 查看全部
Physical sync button on console is broken, how can I fix it?
My xbox one S no longer has a physical button inside the console to press to sync a controller to it. The plastic ‘button’ is there on the plastic case but there is no click when you press it because the button behind the plastic is physically not there.
I looked for other ways to sync a wireless controller but couldnt find anything so I’m guessing I need to replace something so if anybody has any advice I would appreciate it.
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
If you plug the wireless controller in with a usb cable and turn it on this will sync it with the console.  Once there is power in the console & controller you can unplug it and play wirelessly
这个答案有帮助吗?
得分 0
1条评论:
Boo this man!
完成的
添加一条评论
添加你的答案
dsea20 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 2,594
