跳转到主内容
苹果的iPod Touch第六代于2015年7月发布。
149 个问题 查看全部
Why are there vertical lines running down my screen?
I recently replaced the screen on my iPod Touch 6th generation. After I put it back together and turned it on, there were vertical lines running down the screen. I followed the instructions carefully and made sure all the cables were plugged back in. Any ideas what I did wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hello!
Two possibilities: either the replacmeent screen you’ve used is damaged, or the logic board was damaged in the process. Provided that you’ve ensured all connectors are seated properly, you may want to attempt to put the original screen on if it might give you a better idea of what component is faulty.
Good luck!
这个答案有帮助吗?
得分 2
添加一条评论
I dropped my iPod when I was standing up, and when I picked it up there was vertical lines on my screen. My iPod will not turn on. How do I solve this problem?
这个答案有帮助吗?
得分 0
1条评论:
Have you tried holding down the power button and the home button? If that doesn't work, try to connect your iPod to iTunes on your computer to see if that does the trick.
完成的
添加一条评论
添加你的答案
Jason D 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 15
总计 3,803
