connects to tv but not monitor
i own a optiplex 760 usff , it succesfully connects to tv’s using dvi to hdmi, but not dvi to dvi for my monitor
pls help
Based on your responses in this thread, I suspect a DVI-I (male) to DVI-D(Female) may do the trick, the adapter itself is ~$3 online
这个答案有帮助吗?
indeed i believe so too
If your monitors support HDMI, maybe just keep the connection of DVI to HDMI.
Good luck!
这个答案有帮助吗?
well thats the thing i have no hdmi monitors only 15pin vga and dvi
Does the machine have VGA? Because if so, you can use that connection.
my desktop ony has 9 pin vga and dvi
ok, so i looked the optiplex has a dvi-i port but the dvi cable and the dvi to hdmi boh are dvi-d
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 8
总计 273
7条评论
Hi @fegelein3290 ,
What is the make and model number of the monitor?
What resolutions does it support?
Have you tried a different DVI cable?
由 jayeff 完成的
Do you know for sure the monitor works? Have you tried switching inputs on the monitor?
由 Derek Osmulski 完成的
yes ive tried a lot
由 Brayden S 完成的
ive tried on 3 different monitors actually
由 Brayden S 完成的
Are you using the same DVI cable among the 3 monitors as well as the TV? What pin style is the DVI cable you are using vs the pin style on your Optiplex vs the DVI pin style of the TV?
由 Casey 完成的
显示更多的2条评论
