跳转到主内容
加入维修社区 - 创建账户
这是第三代 Apple iPad 4G 版本的维修指南、拆解和故障排除信息,有 16、32 或 64 GB 存储空间可选。于 2012 年 3 月发布。可通过型号 A1430 (GSM, AT&T) 或 A1403 (CDMA, Verizon) 进行识别。维修时需要使用热风并小心撬开。
Replaced digitizer starting to fail
iPad3. Last year I replaced my digitizer/screen with a new iFixit digitizer. Now, the left edge of the digitizer is dead to touch. The dead zone started about 1/8” wide and has grown to about 1/4” wide. Meanwhile the right edge is doing the same thing, about 1/8” wide.
I keep it in a wraparound case and I noticed the left edge is starting to come unglued. Is this related? Can I fix this somehow, or do I need another digitizer?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi @wolfharper ,
I suggest that you contact ifixit regarding the problem with the touchscreen “dead zones”. It never hurts to ask
According to their iPad 3/4 Screen Digitizer parts information, there is a lifetime warranty on their parts
Replace a scratched or cracked front glass screen digitizer panel. This part is compatible with a 3rd or 4th generation retina display model iPad.图片
产品
$24.99
这个答案有帮助吗?
得分 2
添加一条评论
Try re plugging the screen back in. If it doesn’t work, you will have to replace the digitizer again . Let me know results … thank you
这个答案有帮助吗?
得分 0
1条评论:
Yeah digitiser needs to be replaced. I always add b7000 glue on bottom left and clamp down for a while to avoid this problem of the glass getting pushed up via the cable.
由完成的 分享
添加一条评论
添加你的答案
Wolf Harper 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 360
