跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
299 个问题 查看全部
Ipad Air 1st Gen LCD not working after Lightning Connector replacement
Heya,
So my gf's iPad Air A1475 suddenly stopped accepting power charge and no computer recognized it. Apple would charge $300+ to repair it with a new one being quoted at $370+, so she allowed me to try and fix it. This was my first time attempting electronic repair but I'm a fairly capable dude so I researched as much as I could before going about opening it.
We tried hard resetting it and all with no luck - whenever you plugged a cable into the Lightning port the battery symbol appeared on the screen, blinking red but never actually charging. I now feel this was probably rash of me but I ordered a new Lightning Connector and replaced it on the logic board using plenty of flux (channeling my inner Rossmann) which I cleaned with isopropyl.
Reassembled with care and attempted to charge with no luck, now the LCD didn't come on. I did use the alcohol on the LCD-connector on the logic board as a bit of flux had gotten smeared on it - this is one of those things I think might be the cause of this.
Another might be the fact that a flex cable from the power button was slightly ripped when I either took it off or put it back in, but I still believe the LCD should have shown the charger going in.
Checking with a multimeter I can see the battery is accepting power when the cable is connected to a wall socket, but the Ah of the Lightning port itself is a mere 0,44Ah, which according to some sources should be around 2,0.
Apologies for the long question, but any insight would be invaluable (the status of the iPad in my gf's eyes is that it's dead, but I'd still like to try and find out what's wrong and hopefully fix it).
Much love
Johan
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Either a defective replacement charging port flex or replacement charging port was not soldered on properly. Did you see any ripped pads for the charger port on the logic board after removing the old charger port?
I use this video as a reference on replacing charging port on air and air 2:
https://www.youtube.com/watch?v=IdyIQYrO...
这个答案有帮助吗?
得分 3
2条评论:
I didn't see any ripped pads, no, that's what I was expecting to find once I got it open though. Will attempt to resolder it later!
Do you think the sheared power button flex cable could have something to do with this as well? Should probably try to replace that regardless.
完成的
iPad should be able to turn on with a torn power flex, unplug it when testing as it may be making the iPad think the power button is pressed down all the time.
完成的
添加一条评论
添加你的答案
Johan Sturk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 93
