跳转到主内容
The first generation Honda CRV, produced from 1995 to 2001.
Starter doesn't engage. Makes no attempt to crank
It works sometimes. But most times when you turn the key on the lights and everything turns on but the stater win’t crank. Battery has been replaced. Starter has been replaced. Still same problem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Use a multimeter to check continuity of the battery cable from the battery to the solenoid . Have someone else move it while you are checking. It may be partially corroded on the inside.
这个答案有帮助吗?
得分 1
2条评论:
Both battery cables have been changed no difference. Starter also has been replaced. When you turn the key in lights and everything turn on. Sometimes it will crank and start but most times it doesn't do anything. No clicking no lights dimming.
完成的
Sounds like an ignition switch if the starter relay is not clicking in the start position of the switch. When you first turn on the ignition switch but not yet cranking, do you hear the fuel pump PRIME then turn off? The fuel pump should also turn on while cranking, do you notice this also?
完成的
添加一条评论
添加你的答案
metzgerjeffery 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 451
