跳转到主内容
Model A1418 / Mid 2014 / 1.4, 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
50 个问题 查看全部
Change the HHD to SSD
Dear All,
I do have an iMac Intel 21,5” EMC 2805 equipped with the HDD 500G (base model).
Can I change the HDD to a SSD? Specifically with Crucial MX500 CT500MX500SSD1(Z)?
do I need any termal sensor or any other adaptor? I would liketo avoid opening my iMac and then not to be able to close it…
I want to remove the HDD with a SDD not keep the HDD and add the SSD.
thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Here’s the kit you’ll need iMac Intel 21.5" (Late 2012-2019) SSD Upgrade Kit The SSD in the kit is a Crucial SSD.
Follow this guide iMac Intel 21.5" EMC 2805 Hard Drive Replacement make sure you use the correct tools and techniques outlined if you don’t you can damage the display!
iMac Intel 21.5" (Late 2012-2019) SSD Upgrade Kit图片
产品
$89.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ale 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 102
