跳转到主内容
Device and repair information for the 60" LED HD TV by Samsung released in 2013, model number UN60FH6003FXZA.
203 个问题 查看全部
Turned off no response at all while watching a movie
I was watching a movie and in the middle of it the tv just turned off and wouldnt respond even after I unplugged and replugged… its j52000 58 inch Samsung tv..
can you see anything on my picture which would tell u what could be the problem
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
HI,
Does the standby light come on when you turn on the power to the TV?
完成的
Not at all ..
完成的
Hi,
Do you have a DMM (digital multimeter) and know how to use it?
No standby light means for a start that there is no standby power being provided by the power board.
What other power feeds, supplied by the power board, may be missing would have to be tested for using the meter.
If you don't know what you're doing you can cause more problems than what you have now including to yourself as there are lethal voltages present on the Power board when the TV is connected to the wall power outlet
If in doubt - don't, leave it to the experts
完成的
添加一条评论
1个答案
最有帮助的答案
Check that fuse next to the AC in, Do you have a multimeter that will allow you to check continuity?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tin Runescape 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 46
