跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
How to fix the touch screen sensor on a 3g?
on the iphone 3g how do you fix the touch screen sensor? the glass is not cracked just the sensor is not working when i touch it, how dop i go about fixing this.?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Follow THIS guide to check that the cable is plugged in correctly. If all appears correct and the touchscreen does not respond, you may need to replace the touch screen assy
HIH
Replace the glass touchscreen digitizer on an iPhone 3G and fix a cracked or unresponsive digitizer. The front panel does not include the ear piece speaker or home button.图片
产品
iPhone 3G Front Panel
$9.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
logan62589 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 17,058
