跳转到主内容
加入维修社区 - 创建账户
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
iPhone won't turn on, just vibrates 3 times when plugged in.
Hello,
I recently cracked my screen. The phone was functioning since the lcd was displaying lines when turned on. The alarm worked fine and people could call me. All that was broken was the display.
I purchased a new screen and replaced it. While replacing the screen I accidentally broke the home button connector, so I also replaced the home button.
Now the phone does not respond to anything after assembly. It doesn’t boot up. Does not respond to DFG-mode, the mute switch does nothing. I have quadrible checked all the connectors and everything seems to be connected just fine (I followed several YouTube guides)
The only sign of life is when I plug it into the computer - then it vibrates 3 times.
I have tried to connect back to the old screen, but now it too stays black.
Is the phone dead? Do I move on and buy a new one or is there still hope?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Was the battery unplugged during the screen repair? If the screen cables were unplugged or plugged while battery was connected chances are the backlight circuit went bad on the logic board of the phone.
You can shine a flashlight on the screen and see if you can make up a dim image display on the screen indicating no backlight.
A reputable repair shop can fix this for you.
这个答案有帮助吗?
得分 0
1条评论:
The battery was plugged in during the repair.
The phones mute switch doesn’t work and I cannot see anything with a flashlight.
What does that mean?
完成的
添加一条评论
添加你的答案
Rob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,430
