跳转到主内容
第一代索尼的RX100高端小型相机的修复指南和支持。 2020 万像素传感器/ 2012年6月
How can I fix the flash after a fall?
The flash will not open as the body is slightly bent. How can I open it and try a repair? Am I likely to damage the camera when I do this? The camera works just the flash doesn’t.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Your best bet (as with many compact camera repairs) is probably to find another one of the same model on eBay, advertised as “spares or repair” but with a body in reasonably good condition. They generally go pretty cheaply. Practice disassembly on that then you should be able to swap out the damaged parts on your own camera.
A quick Google search gave me a few disassembly videos for that model but not a disassembly guide, though you can find a service manual at
https://elektrotanya.com/sony_dsc-rx100_...
(Be sure to use the inconspicuous download link below the service manual preview, not the large download button which will only give you unwanted software.)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Barbie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 12
总计 1,510
