跳转到主内容
型号 A1059 或 A1099 / 20, 40, 或 60 GB 硬盘 / 中央转盘为触控激活
227 个问题 查看全部
iPod Stuck on Apple logo after Flash Storage mod
Hi!
I have a black and white iPod Classic and I recently bought the Micro SATA Cables CF to 50 Pin 1.8 IDE Adapter, a Digigear SDXCF SD SDHC SDXC to CF Type II Extreme/Ultimate Compact Flash Card Adapter, and a Samsung 64gb MicroSD to SD adapter.
After assembling the whole thing together, I was sadly met with a static apple logo.
I tried to go into disk mode with no success and diagnostic mode didn’t seem to do help me with anything.
Am I doing something wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
Have you tried a different SD card?
完成的
I haven't yet. Could that be the issue?
完成的
The 4 pins on the very left of the HDD cable are not plugged in! Unplug the drive (carefully), re-align, and plug in. Make sure all pins are in!
You’ll also need to reset the iPod, and reinstall the OS.
Good luck!
完成的
添加一条评论
1个答案
Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jaydon 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 20
总计 484
