跳转到主内容
LG在2016年9月29日发布的LG V10的后继产品,类似LG G5。LG V20分为F800, H910, H918, H990 DS Dual, H990N Dual, H990T, LS997, US996, and VS995数个不同型号。同时,提供了钛金灰、粉色等不同颜色。
20 个问题 查看全部
How can I get my display to work again?
My screen came out so I took the phone apart and re-glued the screen with some 1mm 3M tape. Now I reassembled it and it vibrates on boot and I can see the backlight go on because a corner of the screen is broken off… Also WhatsApp Web works. So the phone is definitely working, but the display isnt showing anything (Backlight does work tho)… I re-checked the main screen connector at the bottom and it is properly plugged… what can I do?
P.S.: I followed this tutorial for the process: https://www.youtube.com/watch?v=oDEZjsqN...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
The LCD is for sure broken. In order to get a display back, you will need to replace the screen.
part can be found here: https://www.fixez.com/store/lg/lg-v-seri...
Having a screen with frame saves you the hassle of having to re adhere the screen to its frame, so personally I would go with that part.
Repair tutorial here: LG V20 Display Replacement
Note: If you buy the screen with frame, you start putting your phone back together after step 15 in that repair guide, if you buy screen only, you will follow the entire tutorial.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Raphael Nollau (R4PHikari) 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 8
总计 234
