跳转到主内容
Repair and disassembly guides for the tenth generation Ford Thunderbird.
10 个问题 查看全部
Why is my sony not coming on?
Why is my sony radio not coming on?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi,
Presumably you’re asking about the radio in a Ford Thunderbird, is this correct?
What is the year model of your vehicle?
Have you checked if fuse #11 in the engine bay fuse block is OK?
Here’s a link to a Ford Thunderbird owner manual showing the fuse allocations in the engine bay.
This link shows the location of the engine bay fuse block
这个答案有帮助吗?
得分 2
添加一条评论
If your bird came with JBL system, you will have to rewire all 4 speakers direct to your Sony. I found out the hard way when I installed a Blaupunkt in my T-bird Factory speaker are routed thru the JBL amp. The Ford JBL systems were great when they worked, but a real pain when they quit. It took me the better part of an 8 hour day to accomplice this. Remove the door and rear side panels was not fun, but the results are worth it because my 28 year old JBL speakers still sound great!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
fishingtravis81 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 97
