跳转到主内容
加入维修社区 - 创建账户
微软所制造的笔记本电脑的维修和支持指南。
Can I replace the internal hard drive?
hello,
my internal hard drive seems to be corrupted and the Bitlocker is activated with no password in hand.
so its seems that the solution to fix the problem would be replacing the hard drive. i cant get anywhere pass the troubleshoot when starting up the device.
anyguides on how to proceed to open the device. the process would be just opening the device, taking out the old and placing the new? and how to choose when buy the new hard drive, perphaps improving it since i would be opening it anyways.
really appriciate your help in advance.
Eduar Ryser
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi @eduar ,
What is the name and model number of the laptop?
完成的
microsoft surface book. 8 Gb ram, 256 Gb, Intel 5.
完成的
添加一条评论
2个答案
已选择的解决方案
Bitlocker should not matter. Try booting into windows install USB drive and completely erase the drive.
这个答案有帮助吗?
得分 2
3条评论:
the bitlocker wont even allow me to get into that. i cant access any disk because it says its blocked.
完成的
You don't need to get past the bitlocker, just boot to Surface UEFI, choose boot from external USB and start from Windows installer drive. When you install Windows, delete every partition on Disk 0.
完成的
Also recovery key for BitLocker is usually under your Microsoft Account, or Azure AD account if it is AAD joined.
完成的
添加一条评论
Microsoft Surface Book Teardown
Not sure about the upgrade part. Maybe someone else can help with that.
Good luck
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
eduar ryser 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 198
