Phone not charging after screen repair
Any ideas why phone is not charging after screen assembly replacment. Its stuck on 1 percent battery life???
I think you have damaged a chip on the board or not seated the battery connector properly.
这个答案有帮助吗?
:(.. i hope its not the chip. Bit if it is any possibility of getting a possible logic board replacement, i will disconnect and have a look and reconnect it again...
thank you chris
Chris thing is phone switches on when i plug in the charger but its stuck on 1 percent??? Any ideas
no need for a replacement, a good repair shop that does microsoldering can repair for you
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 158
由 Tracey Homeward 完成的
Help..the chip was replaced but i am being to that the phone still wont charge..does this mean the phone is ruined?
A reputable shop who repaired it should have checked that it charged after repair. What did they say?
This should be repairable.
由 chris 完成的
they said the component is still in place but slightly damaged and cannot be fixed.. i dont accept that, what do u think?
