跳转到主内容
Repair guides and support for all-in-one washer and dryer assemblies as well as stacked units.
139 个问题 查看全部
Hi everyone, my Kenmore 970-c94812 stackable washer-dryer won't spin o
It starts out fine and fill with water.
However, when the wash cycle starts, the agitator won't spin, eventhough the belt at the bottom still spins (video here : https://youtu.be/SaRgXZRHPyQ).
When the rince cycle starts, the tank spins on itself perfectly. Can someone help me find out the problem? Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Cause 1
Agitator Repair Kit
If the washer won't agitate, replacing the agitator repair kit may solve the problem. The kit contains the agitator components that are most likely to wear out and/or fail. If any of the parts are worn out, stripped, or damaged, replace the kit.
Cause 2
Drive Block or Bell
The drive block connects the washer transmission to the agitator. If the drive block is worn out, the transmission shaft will still move back and forth, but the agitator will only move slightly or will not move at all. Inspect the drive block for damage. If the drive block is worn out, stripped, or damaged, replace it.
Cause 3
Motor Coupling
The motor coupling connects the motor to the washer transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Mikael St-Pierre 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 318
