跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
774 个问题 查看全部
Samsung 970 EVO upgrade
Hello, I have a MacBook Pro (Retina, 15-inch, Mid 2015) model 11,5 running macOS High Sierra (10.13.6) and I was was thinking of upgrading the internal SSD to a Samsung 970 EVO. Is this SSD compatible with my MacBook Pro? Right now it has a Samsung 960 EVO. Which Samsung SSD’s are compatible to install in my Mac? Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
960 evo and 970 evo are the same size and use the same connector so I can’t see why not. Or you could use a configuration of [关联产品丢失或禁用: IF123-123] but it would be more expensive so I wouldn’t, 970 evo pro is a similar size and uses the same connector as well so you could use one of those for marginally faster write speeds
这个答案有帮助吗?
得分 1
8条评论:
The EVO SSD's use a different connector system and are not compatible!
完成的
@danj nah I checked, not between the 960 and 970: https://i.ytimg.com/vi/qwIY_fq9wk8/maxre...
完成的
Let me restate it again: The Samsung EVO or PRO SSD's use a different connector than the Apple MacBook Pro's, Apple uses a custom SSD.
Review this guide: The Ultimate Guide to Apple’s Proprietary SSDs
完成的
Funny how Mac's have become, really, a geeks machine. So complex to repair or upgrade. Unfortunately the user base is, generally, about as far from "geek" as you can get, thus all the MAC questions on this board.
完成的
@aactech - It's more of the case Apple thinks and acts differently than the rest ;-}
At one point this made sense as they often did things better! Today it's getting tough for Apple to stand out as most competitors have caught up and in some cases better! Thin & Bling is their focus, so sad the big Performance is no-longer the most important metric! Apple has some good tech that they could leverage to standout again they just keep missing it.
完成的
显示更多的3条评论
添加一条评论
添加你的答案
Ricardo Torres 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 1,301
