跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
20 个问题 查看全部
Dead after 6 months... Culprit is I/O Board Cable?
I’ve had this 2017 13 inch macbook air for six months, and now its dead... sort of. One day after it stopped turning on I went through the usual procedure. SMC reset did work according to the magsafe light but the laptop still wouldn’t boot. After trying lots of things inside the machine, I found that if I unplugged the battery and the cable that runs from the top of the I/O Board to the MLB, the machine would boot just fine. I would plug the cable and the battery back in as soon as the fan started spinning. It worked fine for a week or so, then the same thing occurred. Did the same fix and the machine worked for another week. There has been no damage whatsoever to this machine. Any ideas why this is happening?
UPDATE
Screenshots from Coconut Battery here.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
I would start off checking the battery to see how the charging logic is doing. Install CoconutBattery. Take a snapshot with the MagSafe charger connected and a second one disconnected. Paste both here for us to see 在已经存在的问题里加入图片
完成的
Just added screenshots.
完成的
mmm ... I see zero watts in both. Lets run the battery down a bit ~15 % and test again.
完成的
添加一条评论
1个答案
最有帮助的答案
I’m suspecting the I/O board is the issue. The MagSafe connector cable to the main logic board is likely damaged. MacBook Air 13" Early 2015 I/O Board Replacement.
这个答案有帮助吗?
得分 1
1条评论:
Have tried three known good I/O boards and cables already on this unit. Same issue persists.
完成的
添加一条评论
添加你的答案
William Emanuel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 116
