跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 个问题 查看全部
Spilled cognac on my keyboard, changing logic board.
Hi!
I spilled cognac on my keyboard and after several minutes it just shut down (For obvious reason). I assume the logic board is fried and I bought a new one, but the question here is:
I should probably clean the cognac, but how? It’s underneath the keyboard and how should I clean it?
How can I tell if the old logic board is fried? or is it another component that might be damage? I think I see some areas of the logic board that are darker which could indicate where the liquid is.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You most likely will need to replace the keyboard or the whole top case along with the logic board. You can try cleaning the cognac off the board with isopropyl alcohol, that won’t hurt any of the components any more than they already are. You may be able to salvage the board with that but no guarantees. Its worked for me in the past with many liquid damaged machines.
这个答案有帮助吗?
得分 0
1条评论:
Thank you so much! Appreciate it
完成的
添加一条评论
添加你的答案
Anthony Vu Le 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 69
