跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
20 个问题 查看全部
Boot up issues after logic board swap
I picked up a used mid 2012 non retina MBP with the I5 and 4GB of ram. I bought a certified used logic board 820-3115-B and new ram for it.
I completed the swap, cleaning, new thermal paste ect and attempted to turn it on. Completely dead. I connected it to wall power and the green light on the plug lit up as well as the green battery indicators on the side. I open the lid and there was nothing from the power button. Closed the lid and heard the mechanical noise from the cd player centering itself. Opened the lid again and it eventually booted up but the keyboard was unresponsive.
Shutdown and checked all the connectors. the keyboard cable was not seated entirely. reseated the cable and tried again.
The keyboard backlight comes on but it won’t boot anymore. Also, when the lid is open the “sleep mode” light on the front slowly flashes and goes solid when I close the lid.
Any Ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
What is your drive a HDD or SSD? And what was the MacOS your system had on it before you swapped out the logic board?
完成的
It has the original 500 GB HDD and I believe it's running OS X 10.7.3 "Lion"
完成的
I swapped the old I5 logic board back in and everything works fine. Put the "new" board back in and have the following issues.
Laptop closed white power light is constantly ON.
Laptop open power light slowly flashes and the keyboard back light is on but there is no boot up.
完成的
Sounds like you got a bad part
完成的
添加一条评论
1个答案
try starting the system with the keyboard ribbon cable unplugged using the power-on pads on the logic board and see if works properly with an external keyboard. If it does, you will most likely need to replace the internal keyboard or the entire top case.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
James Sargent 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 67
