跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Using replacement battery kit on phone identified as water damaged
I’m interested in using iFixit’s battery replacement kit for my iPhone 6s. When I took it to Best Buy for the $29 deal last year, they refused to do the service based on the water damage indicator showing pink (I dropped it in the river for a couple of seconds about 1.5 years ago).
I’ve never had any issues stemming from the water damage (that I know of), but my battery could use replacement. My question is whether or not it’s a good idea to use this kit to do it myself. I’ve seen other posts that recommend doing a good cleaning using isopropyl alcohol before battery replacement. Given that I’m completely new to any phone repair, is it worth buying the kit? Any risk of me catching my phone on fire? Battery health maximum capacity is at 83%. Thanks for any advice.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Depends on if you see corrosion e.g white marks inside the phone on any connector or liquid residue behind the screen or board.
Usually it's okay if the sticker just went red but with no signs of liquid inside.
It is worth buying the replacement kit, a battery replacement is fairly cheap and doesn't take long to do while following the iFixit guide.
这个答案有帮助吗?
得分 3
3条评论:
Thanks for your advice. I assume I will only find the white marks once I actually open up the phone, correct? I'll give it a shot.
完成的
Yeah, should be fine. If you see red marks do a quick inspection of the inside of the phone, no need to remove logic board if it looks fairly clean.
完成的
Everything went smoothly and no additional corrosion was found inside the phone. Thanks again for your help!
完成的
添加一条评论
When conducting this repair, ensure that you utilize some heat to loosen the adhesive for the battery. If the battery is punctured during removal, it is highly likely to catch fire. You can utilize 91% alcohol to fight some corrosion and to eat away at the adhesive. Recommend using plastic tools only to lift battery out and add alcohol as you gain space to get through the adhesive. Have fun and use caution. :-)
这个答案有帮助吗?
得分 1
1条评论:
Thanks Jonathan, I appreciate the additional information about removing the battery. I found a friend who has done a few of these repairs to hold my hand during the process.
完成的
添加一条评论
添加你的答案
Matt Gregory 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 77
