跳转到主内容
Samsung Series 5 3G Chromebook. This laptop has a 12.1" Super Bright high-resolution, non-glare display ideal for web browsing.
8 个问题 查看全部
Where's Developer Mode Switch?
The Developer mode switch is supposed
to be in the battery compartment or
behind a removable panel.
It's a very important feature and you
don't mention it all. where is it
located at?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
mine was a device that had no switch near the sim , instead it was inside the small hole in the case to the right of the power button
完成的
添加一条评论
3个答案
已选择的解决方案
The dev switch is accessable without opening the device. It is on the right hand side of the device behind the SIM slot cover.
Edit: You can see it right below the SIM slot on the Step 14 teardown picture.
这个答案有帮助吗?
得分 5
2条评论:
I Have a chrome book and have looked behind the panel where it is supposed to be and there is not a switch there, the hole is but there is not a switch to use?
Any ideas?
完成的
robert clench, did you confirm this by checking the image of the teardown?
完成的
添加一条评论
From what I've read, the developer switch is only on the CR-48 (Prototype/Developer Chromebook) It isn't found on retail models.
这个答案有帮助吗?
得分 1
1条评论:
Not according to what's stated in here. http://goo.gl/b2Fl2
Shell access is only available in Dev mode, if it's not included, a lot of people are going to be angry.
完成的
添加一条评论
The Dev Switch Is On The Right Side Of The Unit, Where The Sim Card Slot Is Located, It's A Switch That Can Be Toggled With A Pin (Paper Clip) Or The Tip Of A Pen.
这个答案有帮助吗?
得分 0
4条评论:
So you are confirming what "no way" answered in June of 2011 correctly. Good Job ;-)
完成的
Wow apparently so , I guess that's what happens when you don't bother to read all posts. My apologies.
完成的
Yup, happens all the time ;-)
完成的
how do u use the switch
完成的
添加一条评论
添加你的答案
William Greene 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 11,103
