跳转到主内容
This is a humidifier with the an R2-D2 theme and appearance. It is produced by Emson.
Where can I get a replacement cord?
We lost the power cord to our R2D2 humidifier.
Where can I get another one?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
You can try a variable ac-dc power adapter then set it to the rating. This is the information I could find in a manual on google.
I’m not sure if the dc connector from this one will fit, you will need to find out the size of the end connector.
https://www.amazon.com/OMNIHIL-Adapter-C...
“ To avoid fire or shock hazard, plug the AC Adapter into the humidifier then plug the humidifier direct to a 120 VAC or 240 VAC electrical outlet. “
Please reference the manual before executing anything. Remember V=IR, P=IV, https://www.sharperimage.com/si/pdf/manu...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Grrrouch64@columbus.rr.com 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 499
