跳转到主内容
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
125 个问题 查看全部
Cellular network connection issues in ipad under OSX (12.1.3)
I had raised this question a week back and may be it was too confusing to attract any notice and draw any answer.  Sorry about that.
The issue is related to ipad air 5 (wifi+lte) with latest osx (12.1.3). I am trying to connect it to the Jio net in India with a Jio 4G SIM card using a “Jio 4GVoice” calling app. I try the following.
·      SIM card is put in the system
·      WIFI is selected (through a personal network)
·      Mobile Data is switched “ON”  (in Settings)
·      Network selection is set to “Automatic
·      LTE is enabled (in Mobile Data options)
Under Settings>General>About  the Carrier is shown as “Jio 35.0 and Network is shown as “Not Available”. Selecting network manually (to Jio4G) has same effect.
·      Resetting network and rebooting repeatedly or switching Airplane mode On and Off has no effect.
·      Change to a different network (AirTel India) has the same effect > Network not available.
·      Followed all steps as suggested in
https://www.igeeksblog.com/4g-3g-lte-not...
From various discussions it appears the network data needs to be updated. For Jio it should be Jio 35.1 instead of Jio 35.0. It probably could be set under Profiles & Accounts. Somewhere it is also suggested to change the configuration. But I don’t know how. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
From what I see, I’m not even sure if the LTE functionality is working in the first place, or if it is even compatible.
Is it a Model 1475 or 1476?
Do you have any example of working model 1475 or 1476 on given networks?
这个答案有帮助吗?
得分 2
1条评论:
The model is "a1475". Unfortunately, I don't have a working model to compare. May be I will try to look for one. But iPhone models running OSX 12.1 have similar problems. However, Clicking on the "Carrier" tab under Settings>General>About
updates the network carrier to Jio 35.1 and the problem is solved. In some cases waiting for the carrier to update also works. Please see the link I had given. Many people report that.
完成的
添加一条评论
添加你的答案
Durga Mahapatra 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 76
