跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2376 个问题 查看全部
How to replace iPhone 4 sim card reader?
I have an iPhone 4 with the sim card reader broken. It was unlocked with a turbosim and the owner forced to extract the sim damaging one of the contacts of the sim reader.
I have the part to replace, but I´m not find a way that convinces me.
Any ideas, suggestions, thanks...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I have the same problem...
can you tell me where to get the part, the sim card reader, or sim card container, whatever it is called.
and if you fixed that, pls inform me at danik_usher@yahoo.com
i would appreciate that
完成的
添加一条评论
4个答案
已选择的解决方案
I´ve get the part from Luna Commerce (China). And I found a guy (I´m live in Argentina) that can repair iPhone logicboards. He could succesfully solder the sim card reader and the iPhone is alive again.
这个答案有帮助吗?
得分 0
1条评论:
you can get the part from united iPhone repair they are in the US and the ship really fast, the part it is only $1.85 , now the real question is who has the skills to solder those 6 pins!!!!
完成的
添加一条评论
最有帮助的答案
It is a very difficult job since the contacts are so small. The sim car reader is very cheap but the job is difficult. I would suggest you find a repair shop that can fix it. Surely the iPhone is worth it. I know these guys do wonders (located in UK) www.ipaqrepair.co.uk
这个答案有帮助吗?
得分 2
添加一条评论
Desolder the existing card reader by use of a heat gun. Then you will use a solder iron to clean up the 6 pads. I use desolder alloy to coat the pads and once the pads are dressed up I reinstall new sim card reader and using a heat gun on low heat melt the reader into place, use a little no clean flux to aid in the solder flow. Make sure to use a good 63/37 solder to anchor the 4 mounting pads. The desolder alloy is electrically conductive and has a very low melting point so you will not damage other components with to much heat, but is very brittle and needs the lead solder to make it hold better.
这个答案有帮助吗?
得分 1
3条评论:
What if 1 of the soldering pads was removed..can it be fixed ?
完成的
Yes, with a lot of skill, it can. In most cases, it's a real PIA to repair removed soldering pads. Sometimes, the pad can be connected using a jumper.
完成的
As u mentioned.a lot of skill which i don't have. Thx for ur reply
完成的
添加一条评论
Hey I have a similar problem somone broke off the SIM card reader tray on my i phone 4 I just need to know where I can get the part asap and how much it will cost to fix it I got phone for 30$
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Flavio 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 8
总计 13,180
