跳转到主内容
Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
212 个问题 查看全部
Not powering on after power supply replacement.
First of all it was not powering on with no LEDs lighting up on the logic board. I got a replacement power supply, fitted it and then I had the 1st LED on but it still did not power on.
I took out the logic board and took out the battery and re-seated the CPU and put it back together and it turned on and booted as soon as I plugged in the power (without hitting the power button). I restarted it several times and then eventually turned it off and tried hitting the power button but it seems like the power button is broken. I could not turn it off by holding the power button in while it was turned on.
Is there any way to short it on the board to see if it powers on and be certain the power button is definitely broken? I can’t seem to be able to find a replacement button anywhere online.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The power button is not an Apple replaceable part ;-{ Its part of the rear case assembly.
You should be able to disconnect the cable and using a jumper short across the sockets solder connections to test the switch logic. Review Step 33 in this guide iMac Intel 21.5" EMC 2544 Logic Board Replacement
这个答案有帮助吗?
得分 0
2条评论:
What is best to use to short the connections? If this doesn't work would would be the issue here? Considering it turns on after removing the cmos battery
完成的
A simple piece of wire will do. Again your assumption was a bad power switch if the jumper fails to turn the system on then you have a power supply issue still.
The NVRAM battery only looses the settings within it.
完成的
添加一条评论
添加你的答案
Daniel Gavillet 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 89
