跳转到主内容
加入维修社区 - 创建账户
1974年发明的3D机械拼图
I Cannot Put Last Piece In
I have watched Every video every guide and cannot get the last piece in
for the new rubix cube
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
It should just snap in place...can you post a picture of your cube and the last element next to it?
由完成的
i cant even get it in i got it in last time but i dont remember how
由完成的
添加一条评论
2个答案
最有帮助的答案
As you probably have seen in the videos and the guides, standard procedure is to build up the cube until only one edge piece (which has two faces) is left. Then turn the top layer 45 degrees and push in the remaining piece. This requires some force, especially in new cubes.
However … You will need all the play that is available in the cube which is why this is best done holding the cube in your hand, not on a hard surface. Allow as many pieces as possible to give way a bit.
Alternatively: Each of the six (one face) centerpieces has a screw inside. You may be able to remove one of the six covers and unscrew the piece.
这个答案有帮助吗?
得分 3
添加一条评论
If the last piece is just an edge piece, pull the adjacent pieces to the side and push in the final piece while you are rotating the the final piece into place. Might take force.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
EZW0RDX 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 41
总计 6,739
