跳转到主内容
加入维修社区 - 创建账户
在日本及欧洲市场作为 Honda Accord (CL9 型) 销售的车型,以 Acura 品牌在美国市场发售。
How to adjust 2004 TSX clutch cable?
All ,manuals I see shown an hydraulic system mine have the sensor by the pedals but behind it is a cable looped end not a pump
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
So it was brought to my attention last week that my clutch engages super low in the pedal travel. If I was in gear, as soon as I started letting the clutch pedal out the clutch started to grab and the car would start to move. I did tons of research on here and couldn't seem to come up with a definitive answer of what was wrong. Until now.
Symptoms:
1) Clutch engagement point is nearly at the floor.
2) The clutch is not slipping. You can test slippage by conducting a stress test. Drive at 45mph in 4th gear at WOT (wide open throttle). Then push the clutch in quickly and release it quickly a single time while maintaining WOT. If the clutch is able to fully reengage and the engine doesn't slip to redline, your clutch surface should be in good shape.
3) Your clutch fluid reservoir is filled correctly. The reservoir location is circled in red in the picture below. If the reservoir low, you won't get proper hydraulic pressure when pushing in the pedal and there won't be enough force to fully disengage the clutch. You can top it off with standard brake fluid.
4) Your clutch pedal bracket is intact. You'll have to get up under the driver side dash to check this out. Remove the lower plastic panel by removing the single screw about where your right knee would be. Then pull on the plastic panel to disengage the 3 clips that hold it in place. This requires a little force.
5) Your master and slave cylinders are not leaking fluid. (I don't know the details on this, but the dealer checked and said they were in good shape).
The Findings
I checked as much as I could and couldn't figure out what was going on so I took it to the dealerTook them ab. out 3 hours, and they determined....that my clutch surface was worn. And it would cost $2000 parts and labor to put in the new clutch and flywheel. Holy !&&*!
At the same time I was wondering, if the clutch surface is worn, how come it ain't slippin'? From what I've read the clutch will slip or engage high when the surface is worn out. I was a bit perplexed, so I came back to the board. I finally stumbled upon a thread where Jtso had recommended the following trick.
The TSX clutch is self adjusting; however, there is a small adjustment you can still make yourself. Here's what you do.
The Fix
Here's the pedal and the push rod that it attaches to:
Look near the hinge of the clutch pedal:
Notice the brass bracket. On the back side of the bracket is a 12mm nut:
Use a crescent wrench turning clockwise to loose this nut. It took a bit of force to loosen. Once the nut is loosened you can twist the push rod clockwise to change the engagement point of the clutch pedal.
I found the easiest way to turn the rod is to spin the 12mm nut all the way to the end and use it to turn the rod with your fingers. Then use a pair of pliers to hold the rod from counter-rotating, loosen the nut from the end and tighten the nut back down against the bracket.
I would guess I gave the rod about 2 complete twists. The engagement point is now a decent ways off the floor and feels very normal. Be careful not to move the engagement point too far out as this may lead to the clutch not fully engaging when you let the pedal all the way out. I haven't had time to test this for myself, but I plan on doing the clutch stress test tomorrow to ensure I'm not getting any slippage. As long as I don't have any slippage I'm going to assume I'm ok.
So I'm fairly confident that I have a long term, reliable fix in place, I saved two grand, and I'm once again shooting to keep the clutch for 200k+ miles!
这个答案有帮助吗?
得分 0
1条评论:
I can’t see your pictures.
完成的
添加一条评论
添加你的答案
Daniel O 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 36
总计 3,227
