Replace screen Ionic - Ionic
I have an Ionic with a damaged screen and the replacement worked until last week firmware update… it is dead since then…
How could I replace the screen from the dead one to the broken screen but working ?
Remove the strap from the wrist
heat the watch slowly to approx. 80 degrees Celsius
gently(!) place a opening tool between the glass and the frame of the watch and lift the glass carefully and slowly
disconnect the connectors
replace the glass
put everything together
WARNING: Be very carefull, since the rubber seal between the glass and frame is easily damaged and you need it to seal the watch. I haven't found any spare part for this yet and I did not managed to preserve it.
这个答案有帮助吗?
Hi! I also have a broken glass on the Ionic. Where can i find the repair guide and parts?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 2,998
1条评论
I found this tutorial on youtube: https://www.youtube.com/watch?v=vZdALycI.... Would be great to see it on IFixit along with parts....
由 DSCantu 完成的
