跳转到主内容
加入维修社区 - 创建账户
A1706/EMC 3071—于2016年11月上市,这台13''MacBook Pro带有OLED触摸条。以双核“Skylake”英特尔酷睿i5 CPU和4个雷电3端口为特征。
MacBook Pro 13'' inch Touch bar model left fan making noises
The left fan makes noises when it runs at around 1800-2400 RPM.
The frequency of the noise decreases as the RPM increases.
Here’s the link to the recording https://instaud.io/3ep1
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Get a small soft paint brush and a can of can’ed air. Follow this guide to take the bottom cover off 2016年末带Touch Bar的13英寸MacBook Pro 底壳更换 Be very careful when prying as you can damage your logic board if you push any tools to far in.
Once the cover is off brush the dust off your logic board and the fan’s. Using short blasts of can’ed air blow away the dust and debris. See if that solves things. If not its a bit of work to get the fans out as you’ll need to take the logic board out and will need a new fan unit.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Shubhang 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 6
总计 916
