跳转到主内容
2015年十一月,华为发布了Mate 8。Mate8搭载了安卓6.0系统,具有6英寸的屏幕。有32GB以及64GB的内存,3GB的RAM以及4GB的RAM两个版本,一个16MP的后置摄像头和8MP的前置摄像头,一个4000毫安时的草鸡大的电池
15 个问题 查看全部
Does changing the battery also require us to change the screen?
I've been having battey charge drop problems. When I go to the Huawei service center they tell me that battery change will also require a screen change. (Without even checking my phone). They say that the battery comes with the screen. My screen is in perfect condition. Is it true that the battery change will also require a screen change?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
@slot1gamer @jayeff Thank you guys. It sounded silly to me as well when they said that the battery and screen both have to be replaced.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Hi @alieffendi ,
Looking at the 华为 Mate 8 电池更换 guide, it is not necessary to remove or replace the display.
If you decide to replace the battery yourself, read the comments at the bottom of the guide for a tip that may be of some help.
这个答案有帮助吗?
得分 3
2条评论:
depending how you look at it, are you removing the screen or removing the back?? hmmmm
完成的
Hi @slot1gamer ,
Fair enough.
I've amended my answer.
Cheers
完成的
添加一条评论
No they are being dumb..
The battery is stuck to the mid frame with some double sided tape, this is a job a day 1 tech can do.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ali Effendi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 126
